Use the following procedure to enable IPsec on an interface. You can configure IPsec on a port, VLAN, or loopback interface.
Management interface does not support IPsec configuration.
Enable IPsec for IPv6 on VLAN 100:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 100 Switch:1(config-if)#ipv6 ipsec enable
Variable Definition
The following table defines parameters for the ip ipsec and ipv6 ipsec commands.
Variable |
Value |
enable |
Enables IPsec on the interface. |
